3-D view pivot problem - aligned with section box
I am having a problem with the extents on a default 3D-view. This seems to only be happening in the Default 3D-view. At first the model was not visible at all. Then I did a zoom-to-fit and realized it was fit to a very zoomed out window and the rotate center point was way out in space. I moved the center point back to the model with the steering wheel, which fixed the problem, but when I closed and reopened the file, the same problem occurred and the center point had moved.
The view and zoom-to-fit is also changing based on if the section box is clicked on or not. The center pivot point seems to be aligning to the center of the section box.
This is a new problem that wasn't present in the file a few days ago. Please help! This is confusing and not sure how to go about fixing it. Thanks.
