2D Shower family from Revit doesn't display lines
3 ANTWORTEN 3
Nachricht 1 von 4
elisag23
335 Aufrufe, 3 Antworten
Hello, I am having this issue with the 2D shower family. It is from the Revit Library.
If I delete the Detail Item from the family, it becomes transparent. I want it to be like the toilet and the sink, with white background. How can I achieve this?Screenshot 2023-11-24 203739.pngScreenshot 2023-11-24 203744.png
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: elisag23
Edit the family and just add in extrusion. When you load into the family, the extrusion will mask the background but it will not appear right in the section or elevation.
If you want alternative, I would suggest using this family.
Nachricht 3 von 4
Go into the Family and in Plan View select Masking Region (Detail Item) and uncheck Draw in Foreground in its Properties.
Nachricht 4 von 4
I think I misread you. You want to mask the background; right? If so, then the Masking Region should be drawn in foreground.  Check to make sure that ALL the Symbolic Linework is set to "Draw in Foreground".
