AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
2d Images of People (entourage)
12 ANTWORTEN 12
Nachricht 1 von 13
kadmonkee
4434 Aufrufe, 12 Antworten
is there an efficient workflow for creating 3d render quality images from a 2d image for use in a Revit 3d view?
I have render quality images (2d only) works great for elevations and sections only
the company is not willing to pay for RPC content.
thank you for any help
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
12 ANTWORTEN 12
Nachricht 2 von 13
ennujozlagam
als Antwort auf: kadmonkee
Hello, you can check @Anonymous.estroescu post he shared 2d images sometime ago. Thanks
Nachricht 3 von 13
kadmonkee
als Antwort auf: ennujozlagam
thank you but this does not help
the link is not associated to anything relevant.
thank you
Nachricht 4 von 13
ennujozlagam
https://forums.autodesk.com/t5/revit-architecture-forum/people-for-elevation-and-section-views-in-re...
Kudos to him. Thanks
Nachricht 5 von 13
loboarch
That is the issue here. RPC IS the way Revit handles this kind of thing.
Revit is shipped with basic RPC sample content so you can see how it works, but additional content must be purchased from Archivision. I suspect the number of hours you might spend in pursuit of an alternate solution would more than pay for the RPC content you need.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 6 von 13
RobDraw
When I started the thread that was linked earlier, I came across a site that had a step by step guide to creating RPC content.
https://enscape3d.com/best-practices-custom-rpc-content/
Rob
Nachricht 7 von 13
Time or money, one must be spent.
You can spend time create images with alpha channel (TIFF or PNG) of people and place over the renderings in PhotoShop. Make a copy of each person, change the tone to back with transparency, skew it to make shadow. Once you have library, it can be done fairly quickly.
It is the '90 workflow, by the way.
Nachricht 8 von 13
kadmonkee
als Antwort auf: ToanDN
I agree Time and (or) money must be spent
money is the cost of operations so I am trying to convince the bean counters of the priority
thanks for the suggestion though (too much time for a maybe we'll build this)
thank you
Nachricht 9 von 13
kadmonkee
thanks for the update
I will review later
thank you
Nachricht 10 von 13
kadmonkee
als Antwort auf: RobDraw
thanks for the info I will review later
thank you
Nachricht 11 von 13
kadmonkee
als Antwort auf: loboarch
exactly , at this point they are not willing to buy the subscription
trying to convince them of the need
thanks
thank you
Nachricht 12 von 13
constantin.stroescu
I often use custom families for entourage because I need non realistic people and trees . In the images from below there are two examples of this kind (black and white)
These families are made using 2d maped images ( I used Mass elements with curved surface having as material an image with cutouts that use the alpha mask of this image).
You have to be careful to rotate them so to be as possible perpendicular on the Camera axis. Your can make other items using the same work pattern.
this is an In Cloud Rendering:
and these in computer with High Screen and Ray Trace (Revit 2017)
the floor plan with entourage families and Camera
I attach the .rvt file , the Material Library and the bitmaps and their alpha masks.....good luck!
Constantin Stroescu
Nachricht 13 von 13
constantin.stroescu
the library and the bitmaps....
Constantin Stroescu
In Foren verƶffentlichen
