I am new to making revit families.
I attached a 2d detail component family to this post.
my question is how to modify the reference planes or other constraints in order to make the symbol work as desired.
I want to make the up down arrows stay where they are while I stretch the left and right arrows and also want the left right arrows stay where they are while I stretch the up down arrows.
please help!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Try this one....I added a vertical reference plane in the middle and set it to origin, aligned and locked the vertical line to that. Aligned and locked the horizontal lines to the reference plane (also an origin) Swapped out the half extent with extent and added a formula to the half extent to give the correct value. Added an equality dimension both directions.
If you are doing structural floor framing plan then check out the native structural Span Direction and Beam symbols.
