i have created this railing (fence) that balusters and baluster panels. i am having a hard time getting the repetition to space correctly. see attach revit file
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
if you were to extend any of those railings you will see that the spacing doesnt keep.
Because a baluster panel has a fixed length dimension. Design the length of your railing to fit the number of panel, or with gaps where make sense.
would you be willing to create an example with one of the railing in the file and upload it?
@jledgewood409 wrote:would you be willing to create an example with one of the railing in the file and upload it?
So, you want to know if I would be willing to fix all these baluster patterns out of the kindness of my heart? Don't you have something more fun?
Here; maybe this will help too:
NOTE: This defines the Main Pattern - the thing that will be repeated.
i am trying to recreate your screen shots as to where the railing start begins with the 3" square baluster followed by the panel. i am matching your "edit baluster placement" window and for some reason the start of my railing begins with the panel? any thoughts? i am attaching a file that reflects this situation.
@jledgewood409 wrote:i am trying to recreate your screen shots as to where the railing start begins with the 3" square baluster followed by the panel. i am matching your "edit baluster placement" window and for some reason the start of my railing begins with the panel? any thoughts? i am attaching a file that reflects this situation.
Define the pattern exactly as I'm showing in message #11 and message #13.
You missed one thing.
i realized i didnt have it set to center just after i sent the message. thank you for all the help
