i have my level set at 4505'-6" and when i take a spot elevation to that level the spot elevation reads 4505'-11 57/64". i cannot figure out what is going on here. please help
Check the Units for the spot elevation and the Project Units. Most likely it is not using the Project Units and rounding differently.
Steve Stafford
Is your level and spot elevation set as project base point or survey?
come to find out that someone moved the project base point in the negative 'z' direction.
Steve Stafford
