2022 - Recurring error message when I open views
8 ANTWORTEN 8
Nachricht 1 von 9
eyalbRAPVR
376 Aufrufe, 8 Antworten
I have a recurring error message when I open views in a specific file. It doesn't happen all the time but most time. Sometimes it recurrs with a specific views, other times it recurrs with different views. A mystery to me... Couldn't track the source of it. I attach the error message screenshot. Revit does not abort the file, it simply refuses to open it. I then need to reopen the file and sometimes it helps and sometimes not. Any ideas?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: eyalbRAPVR
Nachricht 3 von 9
eyalbRAPVR
als Antwort auf: barthbradley
I audit it each time I open the file. Doesn't help!
Nachricht 4 von 9
sureshchotrani
Kindly provide a journal file(named jouranl.00xx.txt) to troubleshoot the issue, details on the journal file can be found at
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 5 von 9
eyalbRAPVR
als Antwort auf: sureshchotrani
I attach the last journal file from yesterday evening. Last time it ocurred. Thanks for your help!
Nachricht 6 von 9
Could be caused by your graphics card driver.  Change your acceleration settings under Options.
"An error has occurred while drawing the contents of this window" in Revit | Revit | Autodesk Knowle...
Nachricht 7 von 9
eyalbRAPVR
It its turned off. We tried this already. Doesn't seem to be the cause...
Nachricht 8 von 9
I have a feeling you've gone done every road I would go down. If I were you, I'd just open a support case through your Autodesk Account at this point.
Nachricht 9 von 9
sureshchotrani
Kindly clean uninstall as per the Autodesk Knowledge Network article- https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-C...
Further follow below steps to install Revit 2022 -
1. Clean temporary files, https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-delete-temporary-...
2. Turn Off User Account Control Settings https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-turn-off-User-Acc...
3. Disable Antivirus software, Firewall & Windows defender
4. Download the software from below direct links, you need to download all parts, once downloaded double click part 1 which will start extraction and later installation will start.
Part 1 -
https://efulfillment.autodesk.com/NetSWDLD/2022/RVT/03BD6A4A-C858-3AD2-9353-DF2974C9918B/SFX/Revit_2...
Part 2 -
Part 3 -
Part 4 -
Part 5 -
