Hi all,
Not sure if this is happening with other user, but when try to use a material tag it will work with a leader, but if you try and tag the same thing with no leader, it wont host.
In that instance it will come up with "X", until you "nudge" the tag
@shane_v wrote:Hi all,
So, you won. You nudged it and the label appeared. Be happy it was so easy.
If you are looking for the reason it happens, it started with the introduction of the new multi-leader functionality. FWIW.
