2021 REVIT- Making wall layers for irregular wall (model-in-place )
5 ANTWORTEN 5
Nachricht 1 von 6
othmannajjar8
374 Aufrufe, 5 Antworten
HI
I have an irregular wall in my project so i use a wall by (the model in place) then I want to export 2d drawings ( lod 300) ,
What is the best way to do this?
note I use initial solve by making (model in place ) inside (model in place ) -image 1-
Please share some options or solutions.
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: othmannajjar8
Export to what?  CAD?
Help | Exporting to CAD Formats | Autodesk
Also, have you considered Wall by [Mass] Face?
Help | Create a Wall from a Mass Face | Autodesk
Nachricht 3 von 6
You can model the insulation as an extrusion in the model in place wall and join it to the in place wall (switch join order so that the insulation cuts the wall).
Nachricht 4 von 6
othmannajjar8
als Antwort auf: ToanDN
thanks. and create wall-by-face on the generic face to get wall layers?
Nachricht 5 von 6
othmannajjar8
als Antwort auf: barthbradley
sorry,but don't mean export to cad, i mean create wall structure layers  on this irregular geometry
Nachricht 6 von 6
You could create wall by face for each layer of brick, not for the entire wall assembly because the thickness varies.  After that I think still need to model the insulation in place.  But you already modeled the entire wall in place then there is no need to go that route.
