Does anyone know if there are any Roof & Floor Framing add-ons that will work Revit 2018 LT?
Gelöst! Gehe zur Lösung
Nope, technically Revit LT does not support Add-ons.... Although supposedly there is a workaround.
You can download individual beams and framing families from bimobject.com such as TrusJoist products.
So basically I would be placing them individually like any other elements?
Just curious...how would it compare to using an add-on? In other words with these add-ons does a person just create a perimeter like drawing a floor or roof and it creates the whole section or complete system?
Revit can do it natively using its beam system tool, which is how you vision it in your question. LT, no can't do. Either manually array or use sloped glazing with custom mullions (I don't know if LT support sloped glazing by the way).
That is what regular Revit does....
Here is the fun part. If you open a project that was created this way in regular Revit, and try to edit it in Revit LT, the panel button is grayed out. It will actually show Beam System and there isn't a darn thing you can do to change it but to explode it, they system that is.
WOW...Thanks guys!
I think I'll go the family route.
Seems like a lot of residential guys use LT and would really love a framing enhancement/add-on.
Thanks again
