Does anyone know if/when the 2018 BIM 360 Add-In for Revit will be released?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
Thanks for participation in our community forum![]()
Check the link here for the latest BIM 360 add-in. (Applies to Revit 2018)
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
DCalloway,
My apologies, you are correct. I got you the wrong link. The one that states how to acquire the Add-ins for Revit is available >HERE<.
The add-in for Revit is BIM 360 Team, however, as of this moment, a very specific search did not provide results for the 2018 version yet.
I have a Screenshot of Revit 2018, on the open dialog, where BIM 360 is part of the accessible Storage Locations. I highlighted it in red.
If you have a subscription, you should have the service.
Thank you @DanFaba
Hi @Anonymous
See here on how to install BIM 360 add-in.
Viveka CD
Guys... I know HOW to install the BIM 360 Add-in... I just need to know where Autodesk PUT it.
I'm having the same trouble here
I've located the BIM 360 Glue add-in for Revit 2017, not for Revit 2018. It says online that the same should apply for Revit 2018, however after installing it nothing shows up. Could it be because I still have Revit 2017 installed?
There is the "chance" that could be it... However, I did not install the 2017 version. There was just not enough there that got my interest. I believe that Autodesk has yet to release the 2018 version to us yet... But why would they put out the 2018 version without all of its supporting software being ready to deploy at the same time? It's funny how ALL of my lesser 3rd party Add-ins were ready when I installed 2018...
Adding more yet to the enigma that is Autodesk...
Hi @Anonymous
Please see discussion HERE to answer you question.
I recommend you to post to the BIM 360 forum for related questions.
Best Regards,
Viveka CD
