2018.2 Fill Patterns don't apply to material
rene_broersen
rene_broersen
After the 2018.2 update I am not able to apply Fill Patterns to the Surface or Cut Pattern of a material.
It remains <none>...
But after editing a pattern and then cancelling the operation the pattern is assigned.
Unfortunately it is not possible to edit the Solid Fill pattern.
Is this a bug?
René Broersen
BRTArchitecten
Alkmaar, the Netherlands
FarhanUddinShaikh
Hi, it could be your software error reinstalling may be helpful to you.
kadmonkee
Revit 2018 is still a work in progress so it could possibly be a bug of some kind
reinstalling it will not help this issue at all
this should always be a last resort (reinstalling)
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
mairh_tsek
Hello all,
I have exactly the same problem. Is there any solution that you provide?
Thank you in advance!
