2015: wall material
2 ANTWORTEN 2
Nachricht 1 von 3
htews
306 Aufrufe, 2 Antworten
2015: wall material
Is there a way for wall materials (in plan) to show different between medium and fine detail levels?
thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: htews
No.  They are hard coded and cannot be changed.
Workaround: create Parts from walls and you can change the materials for Parts and set you floor plans show Parts instead of Originals (Walls).  It's time consuming and you will have abundant of graphics issues at corners because Parts don't clean up the way Wall do.
In my opinion, it's not worth investing your time to.
Nachricht 3 von 3
Viveka_CD
als Antwort auf: ToanDN
Hi @htews
I agree with @ToanDN
Here is a tutorial for creating Parts for walls
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
