I am figuring out that when you add a reveal profile (mortar joint) within a cmu wall family, that there is no control over the lineweight of the reveal?
without using the linework command.
thanks,
Howard
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
yes
Hi
I think you can filter the wall types, and give projection line the thickness you need.( even change colour and line type for that matter )
This way you would be controlling only CMU wall projection lines.. and other walls can show
defauly line thickness ..
Cheers!
Toan,
shallow foundation wall. just to show the type.
created a profile that I can adjust accordingly.
this would be at 3/8" scale. our typical wall section
