2015: Handrail issue
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
htews
1109 Aufrufe, 9 Antworten
I attached a wall mounted handrail to a flight of stairs.  Shows up on the Level 1 (up) but does not show on Level 2 (down).  its there when I move the cursor over it, it there but hidden.
thanks,
Howard
correction:  railing shows but not the 'top of stair extension'
9 ANTWORTEN 9
Nachricht 2 von 10
Sahay_R
als Antwort auf: htews
Can you see it in a 3D view?
1) VG>> Railings - make sure all are checked
2) When you edit a railing, you will find the extension family at the Start and End Post in the Baluster Placement dialog box. Try to take a look at the family and its visibility settings
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 10
htews
als Antwort auf: Sahay_R
OK, but in the Level 2 view, the railing on the opposite side shows. see image.
Nachricht 4 von 10
Sahay_R
Can you share the file?
Rina Sahay
Nachricht 5 von 10
htews
8mb file...too big?
Nachricht 6 von 10
@htews
For some reason the file you sent doesn't look like your screenshot.  Anyways, I think the issues is that the view range is not far enough to reveal the handrail below.  See my screenshots.  I changed the View range directly for the Views to fix them but you can add Plan Regions to take of them as well.  Also, your handrail has duplicate geometry from the top rail and a non-continuous rail in the same location.  I fixed it as well - keep the top rail and remove the other rail.
Nachricht 7 von 10
htews
als Antwort auf: ToanDN
OK, Thank you!
will need to do a refresher course on railings Revit railings for Dummies if I can one.
thought plan region command doesn't work on railings.  I guess you can just not stairs.
Thank you.
Nachricht 8 von 10
htews
know any good tutorials for railings?
thx
Nachricht 9 von 10
Ping @Viveka_CD as she is more resourceful.
I mostly looked at the program's helps, YouTube videos, and learned from others on this very forum.
Nachricht 10 von 10
Viveka_CD
@ToanDN Thanks for alerting me to this thread.
Here are a few resources for handrail tutorials:
  • AKN link HERE
  • REVIT Railing and Posts Tips HERE
  • Forum post on modifying railings HERE
How to create a custom railing - video tutorial below:
Hope you find the above links helpful - and you are welcome to submit any questions you may have on the forums.
