is there a way to pull parameters from a generic model to create a tag?
or do I need to create shared parameters and add them to the model and tag?
thanks,
Howard
If they are not included in the list when you create a label then you need shared parameters.
If they created the parameters using shared parameters then Yes, you can bring them in a Tag. Edit a parameter and see what it is.
