2015: Generic Model lineweight
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
htews
2566 Aufrufe, 2 Antworten
I created a generic model corner mullion w/ a void in the element.  Is there a way to change the lineweight of the mullion without using the LW command (which changes all the lines in the generic model)?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: htews
Edit the family, add a new object style under Generic Model category, assign the elements to this object style aka subcategory, and load in project.  In project, go to Manage, Object Styles, expand Generic Model category, and change the Line Weight for the subcategory.
Nachricht 3 von 3
htews
als Antwort auf: ToanDN
Awesome, Thank you!
strange thing is that it worked in the in all sections/elevations BUT in just 1 view template, it wasn't showing properly.  Realized that in the Graphic Display Options, the Silhouettes was set to Wide Lines instead of <none>.
BUT, I did learn for future use the Object Style for generic model.
thank you.
Howard
