1st Floor Walls are showing up on 2nd floor floorplan
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
10685 Aufrufe, 14 Antworten
I am having an issue with my floor 1 walls showing up grayed out on the floor 2 floorplan. I have checked that the top constraints for the walls are "up to level: Level 2," and have added a floor to level 2. I have also checked the view range for level 2, and it does not extend down to level 1. Does anyone have any idea why this might be happening, and how to hide these walls on level 2?
Thank you!
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Anonymous
Change the view's Underlay to None.
Nachricht 3 von 15
RevitRx
here's where you can find the underlay settings:
www.RevitRx.com
Nachricht 4 von 15
s.borello
Check your view range and turn off underlay.
Nachricht 5 von 15
als Antwort auf: RevitRx
Thank you!
Nachricht 6 von 15
ericboe
Thanks but even with no underlay, some of the walls are showing up??
Nachricht 7 von 15
zaronzjohnson
Even when I remove underlay 1st floor is not only seen, but it also won't let me draw in the area because level 1 is being affected by what I do on level 2.
Nachricht 8 von 15
Mitchell.currie
als Antwort auf: zaronzjohnson
Can you please send a snip of your properties in the problem view.
Nachricht 9 von 15
zaronzjohnson
als Antwort auf: Mitchell.currie
I am sorry I am new to Revit. What is problem view?
Nachricht 10 von 15
Mitchell.currie
Double-check that your view range is above the lower walls (as seen in first image).
Make sure the base of your wall doesn't cut into the top of your lower wall.
Nachricht 11 von 15
zaronzjohnson
This is what its shows in View range. Same as the 1st floor.
Nachricht 12 von 15
Mitchell.currie
When you draw a wall on the second floor what is the base offset and base constraint?
Nachricht 13 von 15
zaronzjohnson
That is what I am trying to figure out. It is first time using Revit. I used autocad mostly for small items and basic 2D chemical engineering related projects. My tutor told me they will help me becuase I set up my whole properties layout wrong at the beginning. Thank you.
Nachricht 14 von 15
shestadKMEUW
no. I'm still having the same issue OP shared
Nachricht 15 von 15
shestadKMEUW
Where/how do you open this box to access these settings?
