Hi all I need a surface pattern 1200mmx1200mm grid pattern with a dashed line. I know is possible to import patterns but I need the .pat
Does anyone has that pattern?
Thank you very much
Gelöst! Gehe zur Lösung
Gelöst von hugha. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von GHASEM_ARIYANI. Gehe zur Lösung
hello
you can use "hatchmaker" lisp in autocad for create any hatch pattern and use in revit.
Insufficient information regarding dashed line.
As fill patterns have no linestyle, you will need to explicitly lay out each dashed line segment.
Hugh Adamson
