8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
edjafer
591 Aufrufe, 8 Antworten
1
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: edjafer
@edjafer wrote:
trying to change the material of my external wall from the browny-yellow to the warmer lighter grey and it refuses to change
How are you trying to change it?
Just post the file here and we'll take a look and see.
Nachricht 3 von 9
edjafer
als Antwort auf: barthbradley
By changing the material of the material of external structural element by editing the wall
Nachricht 4 von 9
That answer doesn't help. Post your file here.  The RVT.
Nachricht 5 von 9
edjafer
Sorry i mistyped, I edit the wall structure and then change the material of the external structure. Hope that’s more clear
Nachricht 6 von 9
 We can have this wrapped up in no time if you just post the rvt.  Otherwise, it's just going to be a back and forth.
Nachricht 7 von 9
edjafer
Ok don’t worry then was just looking for a quick solution this is for work and I’m not allowed to share files .
but you might want to speak a little less condescending towards people I’m only an assistant in my second week.
Nachricht 8 von 9
What? Condescending? That's rude to say. How did you get that tone out of what I wrote?  You're reading something that isn't there. It's only in your head.  I was trying to help.  I no longer am.  Bye, bye.
Nachricht 9 von 9
vitorbortoncello
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
