Revit Custom File Properties
Message 1 of 11
Hi, does anyone know how to access read/write to Revit file custom properties using vb.net & Rrevit API?
All the best
Steve
Replies (10)
Message 2 of 11
jeremytammik
Dear Steve,
These look like properties associated with the specific project document.
You should try to find them using RevitLookup.
That would show you how to access them progrmmatically from your own add-in as well.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
Hi Jeremy,
Using Revit LookUp 2014 was unable to locate the rvt custom file properties!
Any ideas as to how I can read write to these propeerties would be welcome.
All the best
Steve
Message 4 of 11
jeremytammik
Hi Steve,
Sorry about the totally wrong initial answer I gave.
The question came up again now on Stack Overflow, with some more useful answers.
I published a summary of the results here:
http://thebuildingcoder.typepad.com/blog/2015/09/lunar-eclipse-and-custom-file-properties.html#3
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 11
@Anonymous wrote:
Hi Steve,
Cheers,
Jeremy
Hi Jeremy,
Thanks for the link
In the end I used the Revit Project Properties to store the information.
Had to revise the code for Revit 2015 due to the API changes.
More than happy to show/share my add-in if you are interested.
It's a SaveAsTool for BIM, It uses the properties to store Metadata.
All the best
Steve
Message 6 of 11
jeremytammik
Dear Steve,
Congratulations on solving it and publishing your tool!
That is a perfectly viable way to go as well, of course.
The Revit way, in this case  🙂
Thank you for the offer!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 11
Keith_Wilkinson
Is there any way to search for this info within Windows explorer? I'm looking to add a classification system to some of our families and having it as a file property that was searchable would be extremely helpful...
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 8 of 11
jeremytammik
Dear Keith,
Sure you can.
Take a look at the Windows Search functionality:
https://msdn.microsoft.com/en-us/library/aa965362(v=vs.85).aspx
You can program additonal search fields for specific file types, e.g. for RVT.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 9 of 11
Keith_Wilkinson
Thanks Jeremy, however I should add that although this is the Revit API forum I know very little about programming!  Sorry!!
Within the file properties I have the ability to add a field and an associated value.  However this doesn't show up in the list of fields available in Windows Explorer - is this something that would be easy to resolve and give all of our company users access to search?
cheers
K.
Maimonides
Message 10 of 11
jeremytammik
Yes, absolutely.
And it requires programming (I imagine).
Ask any Windows programmer.
Good luck!
Jeremy Tammik
The Building Coder
Message 11 of 11
Keith_Wilkinson
So not easy then... ;o)
Maimonides
