XYZ Point & Vector
XYZ Point & Vector
Arciviz
XYZ Point & Vector
Arciviz
Already I am using AutoLISP Well. I feel very easy by using  List(X,Y,Z) , Polar point & 3D Polar points in AutoLisp.
I know Revit API is very easier if I understand XYZ methods, point & Vector clearly. Any Help?
jeremytammik
Welcome to the Revit API!
The concepts are similar.
In Revit, the XYZ class is used to represent both points and vectors:
https://apidocs.co/apps/revit/2019/c2fd995c-95c0-58fb-f5de-f3246cbc5600.htm
It has some geometrical support functions, and you will probably want to add some own extension methods for your personal use as you go along:
https://apidocs.co/apps/revit/2019/b9b10e41-46c7-7e9b-bbd9-b6180e328d4d.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Arciviz
I think you have explain it clearly in SDK. I forgot the folder name.
Arciviz
I found the util. Thanks.
Sudhan.
Arciviz
Util is good. Please provide if you have any additional document to know more.
