XmlDictionaryReader to XML file
H.echeva
H.echeva
Hello all,
I am playing around with the Revit Server REST API SDK example. I am slowly understanding how it works.
I understand that you make a request and then you get a response in json format, which we then transform with the XmlDictionaryReader to an xml (is that right?). To continue understanding the SDK example I would like to see how that request looks like in xml format. So far I have tried the following:
  XmlDictionaryReader reader = GetResponse(path + "/contents");
           File.WriteAllText("D:\\xmltest.txt", reader.ReadString());
but this doesn't return anything.
Is there a way to export the Request response as an xml? I am very lost in this as I am not used to deal with json or xml programmatically.
Many thanks
jeremytammik
Run your code in the debugger and take a look at the contents and properties of your reader variable.
Jeremy Tammik
Developer Technical Services
The Building Coder
H.echeva
Hello @jeremytammik
Thanks for the suggestion.
Unfortunately, I couldn't make this to work. Using the debugger I see a lot of information but couldn't find the xml itself (see image).
I made some research and apparently this is not as easy as using only one method. I think it is necessary to loop through the nodes and export them.
