Wrapping api element to dynamo element
ameer.mansourWAK8Y
Message 1 of 10
ameer.mansourWAK8Y
For each element two different namespace . i.e. levels
In Revit's API, the Level class' fully-qualified name is: Autodesk.Revit.DB.Level
In Dynamo, the Level class' fully-qualified name is: Revit.Elements.Level
I am creating a Revit API add-in using c# . I want to select an element but wrap it to dynamo namespace.
is that possible?
Replies (9)
Message 2 of 10
jeremy_tammik
Of course it is possible.
I cannot tell you how off-hand myself, I'm afraid, but maybe some other Revit API discussion forum participant can.
Alternatively, the entire Dynamo framework is open source, proving (a) that it is possible and (b) giving you access to the full implementation source code:
https://github.com/DynamoDS
So, you might be able to find out how yourself from the Dynamo source code, or you could ask the Dynamo experts in the Dynamo discussion forum:
https://forum.dynamobim.com
Also, The Building Coder article on a Dynamo zero touch node Revit element wrapper might help:
https://thebuildingcoder.typepad.com/blog/2019/08/zero-touch-node-element-wrapper-and-load-from-stre...
Message 3 of 10
ameer.mansourWAK8Y
hi Jeremy,
i found a solution for that. There is unwrap Method that can be located in
C:\Program Files\Autodesk\Revit 2021\AddIns\DynamoForRevit\Revit\RevitNodes.dll
under namespace: Revit.Elements
a public static class named: ElementWrapper
it contains all the needed wrappers.
Message 4 of 10
ameer.mansourWAK8Y
@jeremy_tammik
sorry to bother you.
I still get this error
and i think i need to initialize documentManager instance
am i right? or do you have any idea about what should i be looking for?
Message 5 of 10
jeremy_tammik
Nope, sorry, no idea. I have never worked with this myself. I would suggest discussing this in the Dynamo forum, unless someone else from here can chip in and help.
Message 6 of 10
ameer.mansourWAK8Y
after digging 6 hours into this problem. I was able to make it work.
it needed to setup an environment like a dynamo environment.
here is my code sample in case anyone needed it.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
 #region Core Logic
                       IList<Reference> refElementsA;
            try
                refElementsA = uidoc.Selection.PickObjects(ObjectType.Element, "Please pick elements (set A)");
            catch (Autodesk.Revit.Exceptions.OperationCanceledException)
                return Result.Cancelled;
// this is must-do assignmet so that we can use wrapper functions
            DocumentManager.Instance.CurrentUIDocument = uidoc;
            List<Revit.Elements.Element> elementSetA = Helper.GetWrappedElements(refElementsA, doc);
            #endregion
//this is must do call as wrapper function opens an transaction but doesn't close it.
//if not called an error will be shown to the user after excuting the command.
            TransactionManager.Instance.ForceCloseTransaction();
            return Result.Succeeded;
        /// <summary>
        /// this is our helper method DocumentManager.Instance.CurrentUIDocument = uidoc must be setted before calling this function.
        /// </summary>
        /// <param name="refElements"></param>
        /// <param name="mainDoc"></param>
        /// <returns></returns>
        public static List<Revit.Elements.Element> GetWrappedElements(IList<Reference> refElements,Document mainDoc)
            List<Revit.Elements.Element> result = new List<Revit.Elements.Element>();
            foreach (var refElement in refElements)
                    var rvtElement = mainDoc.GetElement(refElement);
                    result.Add(Revit.Elements.ElementWrapper.Wrap(rvtElement, true));
            return result;
Message 7 of 10
tomax1029
I'm sorry, but could you help me? I'm doing the same thing, but in Python, here's my code. And all this thing ends with error
# -*- coding: utf8 -*-
import clr
clr.AddReference('ProtoGeometry')
import Autodesk.DesignScript.Geometry
# Import Element wrapper extension methods
clr.AddReference("RevitNodes")
import Revit
clr.ImportExtensions(Revit.Elements)
# Import geometry conversion extension methods
clr.ImportExtensions(Revit.GeometryConversion)
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import *
doc = __revit__.ActiveUIDocument.Document
elements = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PipeCurves).WhereElementIsNotElementType().ToElements()
for i in elements:
    print(Revit.Elements.Element.ElementWrapper.Wrap(i, True))
Message 8 of 10
jeremy_tammik
Your code includes a call to `Elements.Element.ElementWrapper`.
The error message clearly states: 'type' object has no attribute 'ElementWrapper'.
`Element` is a Revit API class, i.e., a type in Python wording.
So, you cannot call ElementWrapper on the Element class.
Please note that this forum is mainly dedicated to the pure Revit API, not Pythons specific issues.
You may possibly find more help and expertise on the latter in the Dynamo forum:
Message 9 of 10
danail.momchilov
Thank you for your post @ameer.mansourWAK8Y !
I've been looking for the location of the RevitNodes reference for Dynamo 2.0 and beyond. There was no information on the web about its new location, so I'm glad you found it! Here's a simple implementation for anyone who might find it useful:
// load Revit api
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
// load Dynamo API (after adding the RevitNodes reference)
using Revit.Elements;
namespace Sample
    public class Sample
        public static Autodesk.Revit.DB.Element ReturnUnwrapped(Revit.Elements.Element element)
            try
                Autodesk.Revit.DB.Element UnwrappedElement = element.InternalElement;
                return UnwrappedElement;
            catch (Exception e)
                throw e;
Message 10 of 10
danail.momchilov
I see this is really old post, but it seems like you are making a script for pyRevit... You don't need to Wrap and Unwrap anything when accessing the API through pyRevit, you can just work with the api elements directly
