WPF Page Resource not found; error
esatis
esatis
when using WPF Page inside of Revit, I get a ton of errors like these:
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='BrowserActiveTabNormalBackgroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='BrowserUnactiveTabNormalBackgroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='ClientAreaForegroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='ClientAreaBackgroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='CanvasActiveTabNormalBackgroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='CanvasUnactiveTabNormalBackgroundBrush'
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='DockWindowButtonNormalForegroundBrush'
E.T.C...
Even if I add CustomResourceDictionary.xaml, I get the same errors.
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
                    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
	<SolidColorBrush x:Key="BrowserActiveTabNormalBackgroundBrush" Color="#FFCCCCCC"/>
	<SolidColorBrush x:Key="BrowserUnactiveTabNormalBackgroundBrush" Color="#FFE5E5E5"/>
	<SolidColorBrush x:Key="ClientAreaForegroundBrush" Color="#FF000000"/>
	<SolidColorBrush x:Key="ClientAreaBackgroundBrush" Color="#FFFFFFFF"/>
	<SolidColorBrush x:Key="CanvasActiveTabNormalBackgroundBrush" Color="#FFDDDDDD"/>
	<SolidColorBrush x:Key="CanvasUnactiveTabNormalBackgroundBrush" Color="#FFEEEEEE"/>
	<SolidColorBrush x:Key="DockWindowButtonNormalForegroundBrush" Color="#FF444444"/>
</ResourceDictionary>
The WPF Dockable page works as expected and all the styling is as set in my pages xaml.
What could be the cause of these errors?
jeremy_tammik
Why do you call them errors? They are marked as warnings. You can probably simply ignore them. You say everything works as expected, and warnings can be ignored.
nice3point
This is normal behaviour, if in runtime you see these colors, as Jeremy said just ignore. In case of errors you will just get exceptions
jw.vanasselt
Is there a way to disable this warnings?
I read in many different forums that this affect the debug performance
