Windows Form in C# Macros
stever66
Advisor Advisor
stever66
I'm trying to get a Csharp Macro to work in Revit 2016. (I'm using SharpDevelop).  I got it to work with
Python in SharpDevelop, but I'm having a hard time with C#.   I'm a beginner at this, so I'm probably doing something simple wrong.
Anyhow, I just want to get a form working that has three buttons - "OK", "Apply", and "Cancel".  This will actually compile, but it won't load into the Revit Macros, so I can't run it.  I have a feeling I have something wrong in the red text, but I'm not sure.  Here is the code:  (sorry, but the formatting got all wacked when I pasted it in.  Hope i have it fixed.)
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
using System.Drawing;
namespace myEditorC {     [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
                                          [Autodesk.Revit.DB.Macros.AddInId("0D7A17A2-B354-40C8-8218-D383A0E62D86")]
public partial class form1 : System.Windows.Forms.Form
            public void Form1()
                this.Text = "My Editor";
                this.Width = 375;
                this.Height = 275;
               //setup the "OK" button
               Button button1 = new Button ();
               button1.Text = "OK";
               button1.Location = new System.Drawing.Point(35, 200);
               button1.Click += new System.EventHandler(button1_Click);
               //setup the "Cancel" button
               Button button2 = new Button();
               button2.Text = "Cancel";
               button2.Location = new System.Drawing.Point(135, 200);
               button2.Click += new System.EventHandler(button2_Click);
               //setup the "Apply" button
               Button button3 = new Button();
               button3.Text = "Apply";
               button3.Location = new System.Drawing.Point(235, 200);
               button3.Click += new System.EventHandler(button3_Click);
               // Set the accept button of the form to button1.
               this.AcceptButton = button1;
               // Set the cancel button of the form to button2.
               this.CancelButton = button2;
              // Set the start position of the form to the center of the screen.
              this.StartPosition = FormStartPosition.CenterScreen;
              Controls.Add(button1);
              Controls.Add(button2);
              Controls.Add(button3);
               }   // end Form1
         private void button1_Click(object sender, System.EventArgs e)
                  //myreturn = "OK";
         private void button2_Click(object sender, System.EventArgs e)
                    //myreturn = "Cancel";
                 private void button3_Click(object sender, System.EventArgs e)
                 //myreturn = "Apply";
          }  // end partial classs
        // start of SharpDevelop Generated macros code
        public partial class ThisApplication
                    private void Module_Startup(object sender, EventArgs e)
                    private void Module_Shutdown(object sender, EventArgs e)
        #region Revit Macros generated code
        private void InternalStartup()
            this.Startup += new System.EventHandler(Module_Startup);
            this.Shutdown += new System.EventHandler(Module_Shutdown);
        }         #endregion
        //end of SharpDevelop Generated Macros Code
public void myEditor()
            UIDocument uidoc = ActiveUIDocument;
            Document doc = ActiveUIDocument.Document;
            Autodesk.Revit.DB.View pView = ActiveUIDocument.Document.ActiveView;Autodesk.Revit.DB.Transaction
            t = new Autodesk.Revit.DB.Transaction(ActiveUIDocument.Document, "Form");
            t.Start();
             try
                        // Create a new instance of the form.
                        System.Windows.Forms.Form myForm = new form1();
                        myForm.ShowDialog();
                 }// end try
             catch
                        TaskDialog.Show("Revit C# Error", "Error");
                  }// end catch
             t.Commit();
        }// end myEditor
 } // end class thisapplication
}//end namespace
Mustafa.Salaheldin
I've modified the code
 * Created by SharpDevelop.
 * User: Mustafa
 * Date: 5/31/2016
 * Time: 7:15 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.Linq;
namespace myEditor
    [Autodesk.Revit.DB.Macros.AddInId("FA1AC762-0901-4B2B-B90B-803AC26177D6")]
	public partial class ThisDocument
		#endregion
            Document doc = this.Document;
            Autodesk.Revit.DB.View pView = doc.ActiveView;
            Autodesk.Revit.DB.Transaction t = new Autodesk.Revit.DB.Transaction(this.Document, "Form");
            t.Start();
             try
                        Form1 myForm = new Form1();
                 }// end try
             catch
                  }// end catch
             t.Commit();
        }// end myEditor
	public partial class Form1 : System.Windows.Forms.Form
		public Form1()
			// The InitializeComponent() call is required for Windows Forms designer support.
			InitializeComponent();
			// TODO: Add constructor code after the InitializeComponent() call.
		void Form1Load(object sender, EventArgs e)
		void Button1Click(object sender, EventArgs e)
		void Button2Click(object sender, EventArgs e)
		void Button3Click(object sender, EventArgs e)
		partial class Form1
		/// <summary>
		/// Designer variable used to keep track of non-visual components.
		/// </summary>
		private System.ComponentModel.IContainer components = null;
		/// <summary>
		/// Disposes resources used by the form.
		/// </summary>
		/// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
		protected override void Dispose(bool disposing)
			if (disposing) {
				if (components != null) {
					components.Dispose();
			base.Dispose(disposing);
		/// <summary>
		/// This method is required for Windows Forms designer support.
		/// Do not change the method contents inside the source code editor. The Forms designer might
		/// not be able to load this method if it was changed manually.
		/// </summary>
		private void InitializeComponent()
			this.button1 = new System.Windows.Forms.Button();
			this.button2 = new System.Windows.Forms.Button();
			this.button3 = new System.Windows.Forms.Button();
			this.SuspendLayout();
			// button1
			this.button1.Location = new System.Drawing.Point(62, 19);
			this.button1.Name = "button1";
			this.button1.Size = new System.Drawing.Size(75, 23);
			this.button1.TabIndex = 0;
			this.button1.Text = "ok";
			this.button1.UseCompatibleTextRendering = true;
			this.button1.UseVisualStyleBackColor = true;
			this.button1.Click += new System.EventHandler(this.Button1Click);
			// button2
			this.button2.Location = new System.Drawing.Point(58, 83);
			this.button2.Name = "button2";
			this.button2.Size = new System.Drawing.Size(75, 23);
			this.button2.TabIndex = 1;
			this.button2.Text = "cancel";
			this.button2.UseCompatibleTextRendering = true;
			this.button2.UseVisualStyleBackColor = true;
			this.button2.Click += new System.EventHandler(this.Button2Click);
			// button3
			this.button3.Location = new System.Drawing.Point(71, 169);
			this.button3.Name = "button3";
			this.button3.Size = new System.Drawing.Size(75, 23);
			this.button3.TabIndex = 2;
			this.button3.Text = "apply";
			this.button3.UseCompatibleTextRendering = true;
			this.button3.UseVisualStyleBackColor = true;
			this.button3.Click += new System.EventHandler(this.Button3Click);
			// Form1
			this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
			this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
			this.ClientSize = new System.Drawing.Size(284, 262);
			this.Controls.Add(this.button3);
			this.Controls.Add(this.button2);
			this.Controls.Add(this.button1);
			this.Name = "Form1";
			this.Text = "Form1";
			this.Load += new System.EventHandler(this.Form1Load);
			this.ResumeLayout(false);
		private System.Windows.Forms.Button button3;
		private System.Windows.Forms.Button button2;
		private System.Windows.Forms.Button button1;
If it works like a charm the mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
hello !
I have a problem with a code in C#, and i have noticed that I have the same with this one ...
For this section:
    #endregion
they told me " 'ThisApplication' ne contient pas de définition pour 'Startup' et aucune méthode d'extension 'Startup' acceptant un premier argument de type 'ThisApplication' n'a été trouvée (une directive using ou une référence d'assembly est-elle manquante ?)", so that maybe there is a reference or a using missing ...
can you help me ? 😄
 ( sorry for my english, I hope i'm clear )
Mustafa.Salaheldin
First: You have to create a separate topic for your issue
Second: What are you tring to do (Revit Macro or Addin)?
Third: I don't speak French.
¯\_(ツ)_/¯
Mustafa Salaheldin
