why “Modify parameters” returns null for newly created Structural Connection?
arvind.maurya37
Message 1 of 19
arvind.maurya37
Using Revit API 2019 and Advance Steel API 2019
I have simple task to connect a beam and column with the Structural Connection (Clip angle) and update its Modify Parameters.
I am able to create a connection between beam and column with Structural Connection (Clip angle) but when i go to modify the Parameters of newly created Structural Connection it gives null
below code to create a connection and modify it
    StructuralConnectionHandler structuralConnectionHandler = null;
        using (Transaction transaction = new Transaction(uidoc.Document, "Create detailed structural connection"))
                    List<ElementId> elemIds = new List<ElementId>();
                    // retrive element from document
                    foreach (int id in selectedIDs)
                        elemIds.Add(doc.GetElement(new ElementId(id)).Id);
                    // The type is from the SteelConnectionsData.xml file.
                    StructuralConnectionHandlerType connectionType = StructuralConnectionHandlerType.Create(uidoc.Document, "usclipangle", new Guid("A42C5CE5-91C5-47E4-B445-D053E5BD66DB"), "usclipangle");
                    if (elemIds.Count() > 0 && connectionType != null)
                        //using (SubTransaction subTransaction = new SubTransaction(uidoc.Document))
                        //    subTransaction.Start();
                            structuralConnectionHandler = StructuralConnectionHandler.Create(uidoc.Document, elemIds, connectionType.Id);
                        //    subTransaction.Commit();
                        uidoc.Document.Regenerate();
                    else
                        message = "There is no element selected!";
                        ret = Result.Failed;
             TransactionStatus ts = transaction.Commit();
       // uidoc.Document.Save();  // tried to save document automatically but gives wired exception eg. Autodesk.Internal Exception
        bool modifyParameters = true// would be setting its value while debug.
        if (modifyParameters)
            // Start detailed steel modeling transaction
            using (FabricationTransaction trans = new FabricationTransaction(doc, true, "Update connection parameters"))
                AdvSteel.FilerObject filerObject = Functions.GetFilerObject(uidoc.Document, new Reference(structuralConnectionHandler));
        //filerObject object is null always
            // this piece of code works independently
                if (null == filerObject || !(filerObject is UserAutoConstructionObject))
                    return  Result.Failed;
                UserAutoConstructionObject asConnection = (UserAutoConstructionObject)filerObject;
                //read connection parameters
                IFiler connectionFiler = asConnection.Save();
                if (connectionFiler != null)
                    //I choose to modify thickess of the base plate
                    connectionFiler.WriteItem(Convert.ToDouble(50.0), "BaseThickness"); //units must be milimmeters;
                    asConnection.Load(connectionFiler); //update connection parameters
                    asConnection.Update();
                    //if the connection parameters are modified, than we have to set this flag to true,
                    //meaning that this connection has different parameters than it's connection type.
                    // not avaliabe in revit 2019
                    //rvtConnection.OverrideTypeParams = true;
                    /// trans.Commit();
Tried So far:
Tried to commit in sub-transaction.
Tried to save the document after commit.
went through below link
Revit Dynamo: revit-api-access-to-structural-connection-parameters
Autodesk Revit API: accessing-detailed-parameters-in-a-structural-steel-connection
Any help or hint would be appreciated!
Replies (18)
Message 2 of 19
RPTHOMAS108
I don't see where the main transaction is started does not follow pattern below:
 using (Transaction Tx = new Transaction(D, "Name"))
                if (Tx.Start() == TransactionStatus.Started)
                    //Something that warrants transaction here
                    Tx.Commit();
This may not be the reason and you should have got Transaction not started exception when you tried to commit it.
You don't need to call Regenerate as this should be internally called after a Transaction/SubTranaction. Saving the document just saves to file so wouldn't help prevent the null.
Message 3 of 19
arvind.maurya37
I just missed to start transaction in the sample code but in real one it is there.
                    transaction.Start();
                    else
                    /// trans.Commit();
Message 4 of 19
Hi Arvind,
Do you get resolution for this stuff. I am also facing same issue. If Yes please let me know as well.
Freelizer
Message 5 of 19
arvind.maurya37
Hi @Anonymous
I just upgraded to Revit API  2020 from 2019
over there it is working fine.
Message 6 of 19
LucasJonnedeJong
Hey @arvind.maurya37
Any chance you can share with me your references and "using" lines?  My GetFilerObject keeps returning null.
Thanks!
Message 7 of 19
LucasJonnedeJong
I got it working in a Revit Addin, but I am trying to get it working inside of a Dynamo Zero-Touch-Node. Any reason why my GetFilerObject returns null inside a Zero-Touch-Node? Any help is greatly appreciated
@jeremy_tammik maybe?
Message 8 of 19
LucasJonnedeJong
Here is my code for those who would not mind to have a quick glance at it, mostly (if not all) copied from the sdk sample.  Anyone, please?
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using RevitServices.Persistence;
using RevitServices.Transactions;
using Revit.Elements;
using System.Collections.Generic;
//using Element = Autodesk.Revit.DB.Element;
//using Element = Revit.Elements.Element;
using System;
using System.Linq;
using System.Diagnostics;
using Autodesk.Revit.UI.Selection;
using Autodesk.AdvanceSteel.CADAccess;
using Autodesk.AdvanceSteel.Geometry;
using Autodesk.AdvanceSteel.Modelling;
using RvtDwgAddon;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.AdvanceSteel.ConstructionTypes;
using Autodesk.AdvanceSteel.DocumentManagement;
using DocumentManager = Autodesk.AdvanceSteel.DocumentManagement.DocumentManager;
using Autodesk.Revit.DB.Steel;
namespace ZeroTouchNodes
    public class SteelConnectionParameters
        private SteelConnectionParameters() { }
        public static string Get(Revit.Elements.Element element, string param)
            Autodesk.Revit.DB.Document doc = RevitServices.Persistence.DocumentManager.Instance.CurrentDBDocument;
            Autodesk.Revit.DB.Element elem = element.InternalElement;
            StructuralConnectionHandler SteelConnection = elem as StructuralConnectionHandler;
            Reference eRef = new Reference(SteelConnection);
            //FilerObject filerObj = null;
            Autodesk.AdvanceSteel.DocumentManagement.Document curDocAS = DocumentManager.GetCurrentDocument();
            OpenDatabase currentDatabase = curDocAS.CurrentDatabase;
            Guid guid = SteelElementProperties.GetFabricationUniqueID(doc, eRef);
            string asHandle = currentDatabase.getUidDictionary().GetHandle(guid);
            FilerObject filerObj = FilerObject.GetFilerObjectByHandle(asHandle);  //keeps returning null
            UserAutoConstructionObject asConnection = (UserAutoConstructionObject)filerObj;
            object paramvalue = connectionFiler.ReadItem(param);
            return paramvalue.ToString();
Message 9 of 19
jeremy_tammik
Can you isolate the problem and create a complete minimal reproducible case for the development team to analyse?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Are you on Revit 2022 or an earlier version?
Message 10 of 19
jeremy_tammik
I went ahead and asked the development team for you... let's wait and see what they suggest first.
Message 11 of 19
vlad_pavel
you should create a fabrication transaction in order to open a steel object
using (FabricationTransaction trans = new FabricationTransaction(doc, false, "Test"))
You can more examples on how to use it in the samples from the Revit SDK packages.
Message 12 of 19
LucasJonnedeJong
Thank you @vlad_pavel
I had just last night come accross a comment of someone saying this, and have made some progress since.  Unfortunately I am encountering new problems:
When I set the readonly bool to 'true'
new FabricationTransaction(doc, true, "Test")
I can now extract the parameter values.    So that is a win for now.  Then of course I want to edit the parameters also, like it was done in the SDK sample.
When I leave the boolean on 'true' and try to write, load and update the UserAutoConstructionObject, Revit crashes.
When I set it to 'false' I get the error message that I can not start a new transaction.  I feel like when I solve that issue, I made it to the finish.  Pleas advise!
Below the code that gives me the error.  Please remember this is not in an external command, but in a zero-touch-node:
using System;
using RvtDwgAddon;
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    [Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)]
    public class SteelConnectionParameters // : IExternalCommand
        public static double Get(Revit.Elements.Element element, string param)
            object paramvalue = null;
            using (FabricationTransaction trans = new FabricationTransaction(doc, false, "Update connection parameters"))
                StructuralConnectionHandler rvtConnection = (StructuralConnectionHandler)elem;
                connectionFiler.WriteItem(Convert.ToDouble(100.0), "BaseThickness");
                trans.Commit();
            return (double)paramvalue;
Message 13 of 19
vlad_pavel
Looks like In dynamo for Revit there are special mechanisms that handle the revit&steel transactions. In zero touch nodes with advance steel API you should use DocContext class from AdvanceSteelServices.dll from [Revit.exe path]\Addins\DynamoForRevit\Revit\nodes\steel-pkg\bin\ . For revit pure API you should use RevitServices.Transactions.TransactionManager.Instance.EnsureInTransaction from RevitServices.dll.
So, for steel transactions in dynamo for Revit please replace
using(FabricationTransaction trans = new Fabrication...)
   trans.commit()
with
using (var ctx = new Dynamo.Applications.AdvanceSteel.Services.DocContext())
Message 14 of 19
LucasJonnedeJong
@vlad_pavel I am so happy, you made my day!  It worked perfectly!
I want to mark your answer as Solution, but I don't think I am authorized to (at least I cannot find a way).  Can someone else please? (@jeremy_tammik maybe?)
Now, I have one more question:    How did you gain this knowledge?   Did you figure it out?   Is there a course I can take?  A book I should read?  A website I should be aware of?
Thanks a thousand!
Message 15 of 19
jeremy_tammik
I accepted Vlad's answer as a solution for you.
Message 16 of 19
jeremy_tammik
Rather belatedly, to answer your other question,  Vlad is an Autodesk employee, and his title is Sr. Principal Engineer in the AEC Design-BID-Buildings department; hence, I assume he is privy to sources inaccessible to mere mortals like you and me 🙂
Message 17 of 19
vlad_pavel
The code of Dynamo-Revit is open source and there I've found how to use the transactions in zero touch nodes. For example this class creates a Wall: https://github.com/DynamoDS/DynamoRevit/blob/master/src/Libraries/RevitNodes/Elements/Wall.cs . Unfortunately we don't have yet any official documentation for this feature
Message 18 of 19
jeremy_tammik
Cool! Thank you very much for clarifying. That helps others to discover more undocumented features and answer their own questions. Better teach a man to fish than to feed him, isn't it?
Message 19 of 19
jeremy_tammik
Thank you for the fruitful discussion! Edited and preserved for posterity on the blog:
https://thebuildingcoder.typepad.com/blog/2021/09/view-sheet-from-view-and-select-all-on-level.html#...
