Why couldn't code rotate model lines on elevation?
I want to rotate the rectangle from top view to working plane, and through code I only realize rotation on plane, unable to rotate on facade.
aignatovich
Hi!
Model line in Revit project can't live alone. It has sketch plane, so, I suppose, it can be moved or rotated only within this plane
Thank you. Is there any other way to solve it?
stever66
continuing the previous response, I would assume you need to rotate the reference plane, and the line should rotate with it.
Maybe someone else can provide more detail?
Edit:
Try looking here for some details:
http://thebuildingcoder.typepad.com/blog/2009/05/model-line-sketch-plane.html
And this is very interesting:  Using delete to find the line and the sketch plane ID:
http://adndevblog.typepad.com/aec/2012/07/get-the-sketch-and-sketch-plane.html
