While running below code im getting thsi error message "Error reading CAD file: Object reference not set to an instance of an object." Please help I'm new to RevitAPI
bim.user23
Observer Observer
bim.user23
Observer
Observer
While running below code im getting thsi error message "Error reading CAD file: Object reference not set to an instance of an object." Please help I'm new to RevitAPI .
using System;
using System.Windows.Media;
using System.Text;
using System.Reflection;
using System.Collections.Generic;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using System.IO;
using System.Windows.Media.Imaging;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
namespace FP
public class Class1 : IExternalApplication
public Result OnStartup(UIControlledApplication application)
application.CreateRibbonTab("Dhana");
RibbonPanel ribbonPanel = application.CreateRibbonPanel("Dhana", "FP");
string AssemblyPath = Assembly.GetExecutingAssembly().Location;
PushButtonData pushButtonData = new PushButtonData("d", "FP", AssemblyPath, "FP.F");
Uri uri = new Uri(@"C:\Users\VENKATA.DANARAO\Downloads\F.png");
BitmapImage bitmapImage = new BitmapImage(uri);
pushButtonData.LargeImage = bitmapImage;
PushButton pushButton = ribbonPanel.AddItem(pushButtonData) as PushButton;
return Result.Succeeded;
public Result OnShutdown(UIControlledApplication application)
[Transaction(TransactionMode.Manual)]
public class F : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
var App = commandData.Application;
var UIDoc = App.ActiveUIDocument;
var Doc = UIDoc.Document;
// Ensure UIDoc and Doc are not null
if (UIDoc == null || Doc == null)
message = "Active Revit Document or UI Document is null.";
return Result.Failed;
Window1 window = new Window1(Doc);
if (window.ShowDialog() == true)
CADLinkType link = window.SelectedCadLink;
// Ensure window.SelectedCadLink is not null
if (link == null)
message = "No CAD link selected.";
String CadLayerName = window.CADLayer;
String FamilyName = window.FamilyName;
// Ensure CAD layer name and family name are not null
if (string.IsNullOrEmpty(CadLayerName))
message = "CAD layer name is null or empty.";
if (string.IsNullOrEmpty(FamilyName))
message = "Family name is null or empty.";
ExternalFileReference externalFileReference = link.GetExternalFileReference();
// Check if externalFileReference is null
if (externalFileReference == null)
message = "External File reference is null.";
var path = ModelPathUtils.ConvertModelPathToUserVisiblePath(externalFileReference.GetAbsolutePath());
// Check if path is valid
if (string.IsNullOrEmpty(path) || !File.Exists(path))
message = $"Invalid file path: {path}. File does not exist.";
IList<XYZ> RevitPoints = new List<XYZ>();
// Try to read CAD file
try
using (Database Acdb = new Database(false, true))
Acdb.ReadDwgFile(path, FileOpenMode.OpenForReadAndReadShare, true, null);
using (Autodesk.AutoCAD.DatabaseServices.Transaction ATrans = Acdb.TransactionManager.StartTransaction())
BlockTable blockTable = ATrans.GetObject(Acdb.BlockTableId, OpenMode.ForRead) as BlockTable;
// Check if blockTable is null
if (blockTable == null)
message = "BlockTable is null. Could not retrieve the block table from the CAD file.";
BlockTableRecord modelspace = ATrans.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
// Check if modelspace is null
if (modelspace == null)
message = "ModelSpace BlockTableRecord is null. Could not retrieve model space from the CAD file.";
// Iterate through entities in modelspace
foreach (ObjectId objectId in modelspace)
Entity entity = ATrans.GetObject(objectId, OpenMode.ForRead) as Entity;
// Debugging: Log entity information
if (entity != null)
// Log details for debugging purposes
System.Diagnostics.Debug.WriteLine($"Entity Layer: {entity.Layer}, Entity Type: {entity.GetType().Name}");
// Check if entity matches the CAD layer
if (entity.Layer == CadLayerName && entity is BlockReference dbpoint)
Point3d position = dbpoint.Position;
XYZ P = new XYZ(position.X, position.Y, position.Z);
RevitPoints.Add(P);
else
message = $"Entity is null while iterating through modelspace for ObjectId: {objectId}.";
ATrans.Commit();
catch (System.Exception ex)
message = $"Error reading CAD file: {ex.Message}";
// Get the FamilySymbol for placing instances
FamilySymbol familySymbol = new FilteredElementCollector(Doc)
.OfClass(typeof(FamilySymbol))
.Cast<FamilySymbol>()
.FirstOrDefault(f => f.Name == FamilyName);
// Check if familySymbol is null
if (familySymbol == null)
message = $"Family '{FamilyName}' not found.";
// Activate family if not active
if (!familySymbol.IsActive)
familySymbol.Activate();
Doc.Regenerate();
// Place family instances at the collected points
using (Autodesk.Revit.DB.Transaction Trans = new Autodesk.Revit.DB.Transaction(Doc))
Trans.Start();
foreach (XYZ g in RevitPoints)
FamilyInstance c = Doc.Create.NewFamilyInstance(g, familySymbol, Autodesk.Revit.DB.Structure.StructuralType.NonStructural);
Trans.Commit();
longt61
That is a really long code file. Maybe you should pinpoint where the exception happens and summarize what you were trying to do and how you did it so that we can get a better understanding and help you.
My fuzzy guess is that you try to read and modify a CAD link instance in your Revit document. Normal, that would not be possible without some tricks or workarounds because you need a AutoCAD API context to directly do it instead of Revit API. That is why one of the AutoCAD object is null and you received such exception.
jeremy_tammik
Welcome to the Revit API! I suggest that you start with simple things that work, and run through a couple of tutorials like the My First Revit Plug-in or others. Do things that work first and understand the basics, before trying to tackle problematic tasks and error messages. Have you taken a look at the getting sytarted material already?
That said, the error that you are encountering os a very common .NET error that can be caused by many things:
To fix it, it helps to understand what is causing it. To do so, run your code in a debugger, step though it line buy line, and observe the values of all the variables. At some point, the null reference will be hit and you will be able to see what is causing it.
