while calling function through user-interface(windows form) Revit transaction
while calling function through user-interface(windows form) Revit transaction throws an error "Starting a transaction from an external application running outside of API context is not allowed."
help, appreciated.
Thanks.
RK.
jeremytammik
Dear RK,
I assume you are new to Revit programming?
I suggest that you first of all take a look at the getting started material and work through the step-by-step instructions provided by the DevTV and My First Revit Plugin video tutorials:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will show you what other important material is available that you MUST be aware of, answer this question of yours, and many, many more besides.
Your question has to do with a valid Revit API context and is discussed in detail in these articles:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Good luck and have fun!
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks for the information, i'm trying to solve.
-RK.
