Which button is clicked?
Message 1 of 8
The addin I am writing adds a ribbon panel with two buttons (button A and button B) to the "Add-Ins Ribbon".
Clicking these buttons will both execute the "Public Function Execute(commandData As Autodesk.Revit.UI.ExternalCommandData, ByRef message As String, elements As Autodesk.Revit.DB.ElementSet) As Autodesk.Revit.UI.Result Implements Autodesk.Revit.UI.IExternalCommand.Execute"
I would like to know which button is being clicked (A or B).
How can I determine this?
P.s. In my .addin manifest, I have defined only one "Command", so under the "External Tools", only one command show up (as expected).
Replies (7)
Message 2 of 8
To my knowlege this info isn't passed on by the API. There are ways around it though as discussed in this post from a couple years back:  http://forums.autodesk.com/t5/Revit-API/Which-pushbutton-caused-the-ExternalCommand/m-p/3698908
Is there a reason that you can't just have a separate command for each button?
Message 3 of 8
Having a separate command for each button is no problem...
...except that I don't even know how my current buttons are currently "linked" by the  ".addin manifest" to the "Execute command".
The way my addin looks right now: a panel with two buttons on the Addin Ribbon and one command under the "External Tools"...but they are ALL connected to one and the same Execute command.
I hope you understand what I am trying to say. Maybe you can show me an example of having multiple commands (linked to different buttons)?
Message 4 of 8
I typically create an Addin Application and then have all command buttons created and associated to the commands during the OnStartup method of the addin. I have linked an example visual studio 2010 solution set up for Revit 2014, it's very bare bones but take a look to see how it's done.
Message 5 of 8
Right! That example makes perfect sense. I was writing all the code in one class, you wrote a class for each button/command.
The only thing missing in your example is the ".addin manifest", but I bet I can recreate it.
Thanks a ton for sharing that example!
Message 6 of 8
No worries glad to help.
BTW I did include a manifest in the zip file it is called RibbonExample.addin
Message 7 of 8
jeremy_tammik
Dear Teun Ham,
This question has actually been discussed a couple of times in the past, so I added an explanation of it to The Building Coder as well:
http://thebuildingcoder.typepad.com/blog/2013/01/url-and-other-buttons-xyz-points-and-vectors.html#2
Best regards,
Jeremy
Message 8 of 8
Aaah, I missed it completely. I guess I expected it was an ".suo" file (Visual Studio Solution User Option). I will pay better attention to the file extension next time 🙂
