Where is the Revit 2014 SDK
mononull
mononull
I cannot find the SDK for Revit 2014.  Where can I find it online?
jeremytammik
All the Revit SDKs are provided in the Revit Developer Centre:
http://www.autodesk.com/developrevit
Autodesk only provides support going back three releases.
What in heavens name would you want to program for Revit 2014?
In any case, you do not need the SDK to program for Revit.
All the API functionality is provided by the Revit API assemblies included with Revit.exe.
If you have Revit 2014 running, you already have the Revit API assemblies installed and can use those.
All the SDK provides in addition to that is documentation and samples.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
mononull
Thanks.  I should've been more specific, but what I'm looking for is the documentation, the Revit 2014  API reference guide (chm file).
jeremytammik
Yes, that helps.
In that case, you are in luck:
The Revit API reference documentation help file contents are available online:
http://thebuildingcoder.typepad.com/blog/2016/08/online-revit-api-docs-and-convex-hull.html#2
Revit 2015, 2016, 2017:  http://www.revitapidocs.com
Revit 2014: http://revitapisearch.com
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
