What version of Visual Studio for this project?
Message 1 of 8
I just installed the Revit API. Tried to compile this:
Custom Exporter to XML
Custom Exporter to XMLCustom Exporter to XML
and got many error messages.
TIA,
-Ramon F. Herrera
JFK Numbers
Accepted solutions (3)
Replies (7)
Message 2 of 8
RPTHOMAS108
Looks like Revit 2014 (.Net 4.0 there was no change that year, changed to 4.0 for 2013 I believe).
The icon of the .sln file indicates: VS 2010. You can just upgrade it, the errors will be due to changes in the API since.
Message 3 of 8
I think the icon of the .sln file gives the game away: VS 2010. You can just upgrade it.
Yes, my icon says "2010". However, my VS-2017 chokes with namespaces, etc. I will go to the office where I have a PC running 2010 and another running 2013 to see what happens.
Thanks!
-Ramon
JFK Numbers
Message 4 of 8
RPTHOMAS108
Was able to build it in 2013 for 2020, file attached.
Had to comment out the following as it is no longer valid:
//public void OnDaylightPortal( DaylightPortalNode node )
Apparently a lot has changed with the exporter since this was written so not sure if the results will be as desired.
Message 5 of 8
Do you mind trying to build the Exporter to XML?
I am so frustrated, that am considering using the Navisworks API instead.
-Ramon
JFK Numbers
Message 6 of 8
RPTHOMAS108
It builds but it doesn't run, probably a required value is not set somewhere. This is an old file and they've changed the rendering mechanism in Revit since, there were a lot of changes to IExporter for that at the time.
Message 7 of 8
RPTHOMAS108
@Anonymous  this seem to be working now, code was pointing to a hardcoded output path.
Message 8 of 8
Thomas: I downloaded and built your Custom Exporter Collada in VS-2017.
The only change needed was switching to Target .NET Framework to 4.7.1
Thanks!
-Ramon
JFK Numbers
