What is the best way to place wall/face based lighting fixture family instances ?
Jan-GJ
Jan-GJ
For my project I would like to place wall/face based lighting fixture automatically through the revitAPI.
Which of the 13 provided methods would be the best for placing a lighting fixture that is wall based. And which for a lighting fixture that is face based. I already have the wall element I want to place the lighting fixture onto and also its XYZ position.
Any resources or code examples would be very appreciated.
jeremy_tammik
I assume you know how to achieve what you ask for manually through the UI, and the best practices to apply there. That is a good start, because then you can analyse the models you create manually using RevitLookup to see what elements are being used and analyse their properties and relationships.
Here are some discussions on picking the right overload:
Here are some discussions on placing lighting fixtures:
I hope this can be of some use.
