What happened to toggle halftone command in revit 2025?
kim_tolsma
kim_tolsma
Hi all,
In the office i work in, The EOH command is invaluable. It seems to have been removed in version 2025.
Is this a Revit LT thing or is it across the board?
Has it been removed by design or by mistake?
I know there are ways around it as EOD still works but it seems strange to me that you would just remove a command that has been around for years
jeremy_tammik
Unfortunately, this is not the best place to ask such a question. Please note that this discussion forum is dedicated to programming Revit using the Revit API. Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface. In that case, you will probably get more optimal answers to a question like yours relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
I hope this clarifies. Thank you for your cooperation and understanding.
Best regards,
Jeremy
kim_tolsma
Yeah cheers.
I realized this was the wrong place after i posted it and couldn't  work out how to delete it.
