Ways to measure plugin usage?
eric.isaac2KKE9
eric.isaac2KKE9
Is there a way to measure plugin usage in a Revit model via the API? Hoping there may be some way to hook in to some sort of "on plugin launch" event, or find the stats elsewhere, since it might save me some time (vs. trying to collect the info plugin-by-plugin).
I am trying to get a better idea of which plugins are being used (to better guide custom development). Continuing to look through the docs, but haven't found something that fits the bill yet.
ricaun
The is no such measuring usage in the API, trying to collect the info plugin-by-plugin is the way.
And gonna depends on what exactly you want to measure, how many times a command is used maybe.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
eric.isaac2KKE9
Thank you for confirming @ricaun , figured it was at least worth asking before sinking too much time into a custom solution. Mostly exploratory at this point, so likely just how many times the command is launched to start.
