Warning Data in Revit Lookup Tool?
Samuel.Arsenault-Brassard
I use the Lookup tool to navigate behind the scenes in Revit, since I don't code.
I've looked for information on warnings for particular objects and I've peeked in the "Snoop DB" that shows "everything" in the Revit project, but cannot find anything related to warnings in selected elements or in the whole list.
Does the lookup tool expose the Warning information at all? If so, how can I access it? Thank you.
RPTHOMAS108
Yes there is the API method Document.GetWarnings
To navigate to the Document object you'll have to use something other than Snoop DB i.e.:
Snoop Application, then pick Document from document set
Snoop Active View, then pick Document
Snoop Current Selection, then pick Document
Thank you for the quick and helpful response! 🙏
