Wall corner connection issue with two angled walls
F_Bgdh
Message 1 of 21
F_Bgdh
Hello everyone,
I am trying to create a wall that forms an angle. Since I couldn’t achieve it directly, I tried to model it using two separate walls. However, the problem is that these two walls remain separated and do not join at the corner, as shown in the attached image.
Is there any way in the Revit API to properly join two angled walls so that they form a continuous corner without gaps?
Thank you in advance for your help.
Replies (20)
Message 2 of 21
Charles.Piro
first question ! Do you have the same endpoint for the two walls to be joined ?
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 3 of 21
F_Bgdh
hi
The short wall’s endpoint is the starting point of the long wall
Message 4 of 21
Charles.Piro
I think , to start, you need to check if the jonction is allowed. Here is the code to check that :
//0 is the index of the endpoint
bool IsAllowJoin1 = WallUtils.IsWallJoinAllowedAtEnd(wallElement1, 0)
bool IsAllowJoin2 = WallUtils.IsWallJoinAllowedAtEnd(wallElement2, 0)
After, if the join isn't allowed, you can permit it for both elements :
WallUtils.AllowWallJoinAtEnd(wallElement1, 0);
WallUtils.AllowWallJoinAtEnd(wallElement2, 0);
If the result isn't good, you can try attaching the geometries :
JoinGeometryUtils.JoinGeometry(doc, wallElement1, wallElement2);
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 5 of 21
F_Bgdh
I tried the solution you suggested. It does work, but the two walls are still not properly joined.
Message 6 of 21
Charles.Piro
thank you for your feedback.
Inside Revit UI, when you tried to join them using this function :
what is the result ?
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 7 of 21
F_Bgdh
When I try to join the two walls with the Revit functions, they don’t join correctly — it only works if I extend the walls manually, or if I create reference planes to align their endpoints.
Another important point: I need to disable all wall joins in the project, otherwise the model becomes incorrect. That’s why I created a method to allow the join only for these two specific walls.
Message 8 of 21
Charles.Piro
can you share part of your Revit project with 2 unjoined walls ?
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 9 of 21
F_Bgdh
Message 10 of 21
Charles.Piro
Sorry if I wasn't clear. I was thinking of an attached Revit file !
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 11 of 21
F_Bgdh
Message 12 of 21
Charles.Piro
Just with problematic walls. 😉
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 13 of 21
F_Bgdh
hi,
Message 14 of 21
Charles.Piro
thank you for the file. The problem is your Updater whose disallow the junctions. Without it, I can join the walls manually and programmatically :
I think the best way is to exclude these elements from your Updater using a specific static list.
PIRO Charles
Developer
PIRO CIE
Linkedin
Message 15 of 21
F_Bgdh
Thank you for your explanation. I’m not sure I fully understand your solution.
Could you clarify what you mean by excluding these elements from the Updater using a specific static list?
  • Do you mean I should create a list of walls that the Updater will ignore?
  • How exactly should I implement this in my project so that only these walls can join while other walls remain unaffected?
Thanks a lot for your help
Message 16 of 21
F_Bgdh
I tried your solution, but now I face a new issue: there is a height misalignment between wall1 and wall2. Here are two views: one in plan, and another one showing the vertical offset.Capture d'écran 2025-09-01 173056.pngCapture d'écran 2025-09-01 174732.png
Message 17 of 21
kamaluddin.shaikh9
Use wall join command from modify tab and make it miter join
Message 18 of 21
F_Bgdh
hi @kamaluddin.shaikh9,
I previously solved the issue by re-enabling the wall join for the two walls specifically, but that caused a vertical offset between wall1 and wall2.
Now with your solution (using Wall Join → Miter), should I apply it alone instead of my previous solution, or should it be combined with the previous fix?
Message 19 of 21
F_Bgdh
 @kamaluddin.shaikh9   @Charles.Piro the Wall Join → Miter Join from the Modify tab in Revit. I wanted to ask: is it possible to reproduce the exact same Miter Join behavior programmatically using the Revit 2024 API?
Can this be done directly after wall creation, or do we need to implement a custom method to simulate it?
Message 20 of 21
F_Bgdh
I tested the Wall Join → Miter Join method manually, but the walls are not joining correctly.
