Walkthrough: Add Hello World Ribbon Panel - Not working with Revit 2019
Hi Team
I have go through http://help.autodesk.com/view/RVT/2019/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_G...
Not found Name of application/Ribbon Panel (Like available for Hello World Demo in Addins -> External Tools -> HelloWorld)
->ExternalCommand Bind Successfully But unable found linking for ExternalApplication Demo
->Visual Studio 2015 + Revit 2019
-> Please HELP Me.
jeremytammik
The URL you pasted does not work for me.
Do you mean this one?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Yes
jeremytammik
I see that the figures are missing in that guide.
I reported the problem to the development team in the issue REVIT-132224 [API docs developer guide: figures missing in hello world].
Thank you for making us aware of this.
You might be able to look at the version for Revit 2018 for the time being:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_G...
The content has hardly changed, and the images are intact there.
Cheers
Jeremy
Jeremy Tammik
The Building Coder
I followed same steps.
But not found Ribbon panel in Add-Ins Tab.
Is there setup except code(Build Successfully) and Addin files(set at C:\ProgramData\Autodesk\Revit\Addins\2019\<name.addin>)
jeremytammik
That is all.
You also need to ensure that the assembly path pointing to the compiled DLL is correct in the add-in manifest.
Jeremy Tammik
The Building Coder
