Visual Studio 2026, when debugging revit screen flickers
minix6800
minix6800
not sure if anyone else had this issue, when I try to debug in Visual studio 2026, as soon as I open a project, revit screen starts to flicker.
I have tried with no could, using a template to start a fresh project and same issue.
Thanks in advance for your help and support
AEC_Revit_Lab
Update Revit and the GPU driver, then disable Revit hardware acceleration under File > Options > Hardware and restart. If flicker stops, it is a graphics issue, not the add-in template. If it persists with a no-op external command, save the journal for Autodesk support. Hope this helps. If it solves the issue, you’re welcome to mark it as a solution so others can find it more easily.
minix6800
I tried few different things and none of them worked
Ended up exporting my setting from VS2022 and importing them to VS2026 and that seems to have resolved the issue.
Thanks for your help anyway
