VIEWSECTION level wise
How do I get all the viewsection related to each levels.I want to populate a drop box with all the view section names plus its level.
Thanks & Regards
jeremytammik
Dear Sanjaymann,
Set up the required structure of levels and section views in a Revit model and explore it using the RevitLookup database exploration tool.
Once you have found the required relationships interactively, you can look at the source code in the debugger to see how they can be followed programmatically.
For an even more interactive exploration, you can use the Revit Ruby or Python shell:
http://thebuildingcoder.typepad.com/blog/2013/11/intimate-revit-database-exploration-with-the-python...
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
