ViewPort Filtering
ViewPort Filtering
Message 1 of 9
ViewPort Filtering
Hi All,
I am trying to filter all the viewports that I have inside a Revit project (used or not used). So far I have written something like this (It is in Python and it is based on the follwoing link https://forums.autodesk.com/t5/revit-api-forum/filtering-viewport-types/m-p/9287944#M44258:
viewport_list = []
viewports = FilteredElementCollector(doc).OfClass(ElementType)
for element in viewports:
       if element.FamilyName == 'Viewport':
              viewport_list.append(element)
When I try to print the name of these viewports it gives me the actuall system family name which is Viewport!:
for vp in viewport_list:
      print(vp.FamilyName)
So the only thing printed is Viewport.
So the thing is I want to find an specific viewport with the name "XXXX" . But i don't know how to do that cause I can't get access to the names of the viewports!
Any help would be much appreciated.
Dave
Replies (8)
Message 2 of 9
jeremytammik
Use RevitLookup and other database navigation tools to explore your model and research what criteria you can use to identify the desired viewport:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
https://thebuildingcoder.typepad.com/blog/2013/11/intimate-revit-database-exploration-with-the-pytho...
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
BenoitE&A
See Jeremy's post, it answers most of questions.
In your case element.Name could be the solution.
In addition, you can access to the parameters of an Element using :
Parameter p = elem.LookupParameter("nameOfParameter");
And then get the value of the parameter using
if(p != null)
if(p.StorageType == StorageType.ElementId)
string valeur = elem.LookupParameter(nom).AsElementId();
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Message 4 of 9
Yien_Chao
try this :
viewport_list = []
viewports = FilteredElementCollector(doc).OfClass(Viewport)
OUT = [i.get_Parameter(BuiltInParameter.VIEWPORT_VIEW_NAME).AsString() for i in viewports]
Message 5 of 9
Thanks for the reply Yien_Chao,
I used the code, but the result is just an empty list, The reason is, I haven't used any of the viewports inside the project so there is nothing to filter. I want to filter all the viewports that are inside the Revit project (even those that are not used).
So the code below gives me all the viewports inside the project but as I said I can't access their name, the error says there is no attribute Name!
col = FilteredElementCollector(doc).OfClass(ElementType)
for c in col:
     if c.FamilyName == 'Viewport':
     print(c.Name))
Message 6 of 9
Thanks BenoitE&A:
My Original problem was that the "Name'' attribute is not accessible, when I try to use it it gives me an error that there is no Name attribute.
So I tried to use your code, it still doesn't give me anything, maybe I am doing something wrong!
     for vp in viewports:
      if vp.FamilyName == 'Viewport':
           p = vp.LookupParameter('Title')
           if p.StorageType == StorageType.ElementId:
                 print(p.AsString())
This gives me multiple ''Nones''
Message 7 of 9
Yien_Chao
Oh! Then its not a viewport but a view.
Viewport is only placed view on sheet i believe.
Message 8 of 9
Thanks Jeremy,
I will look into it more but still haven't found anything that helps me with my probelm, used all the BuiltInParameters available for view ports:
VIEWPORT_ATTR_ORIENTATION_ON_SHEET
VIEWPORT_ATTR_SHOW_BOX
VIEWPORT_ATTR_SHOW_EXTENSION_LINE
VIEWPORT_ATTR_LABEL_TAG
So the only one that actually gives me something is the last one, when I try to print it shows that there is something available but when I use AsString(), it gives me ''none''. Here is the code:
for c in col:
            print(c.get_Parameter(BuiltInParameter.VIEWPORT_ATTR_LABEL_TAG).AsString())
This gives me ''none''.
Apparently the only way to access the viewports that are available but not used inside the project is to filter through the ElementType like the code I have written above.
I tried to filter by the category or class:
col = FilteredElementCollector(doc).OfCategory(OST_Viewports)
This is empty
col = FilteredElementCollector(doc).OfCLass(Viewport)
This is also empty
for c in col:
           print(c.FamilyName)
This is not empty and it gives me exactly ''Viewport", but when I try to access the Name it gives me error:
          print(c.Name)
This is the error:
line 166, in <module>
AttributeError: Name
Message 9 of 9
So Finally I managed to do it, thanks for the help all,
I did it like this:
list = []
collection_ports = FilteredElementCollector(doc).OfClass(ElementType)
for c in collection_ports:
       list = c.GetOrderedParameters()
       for l in list:
            try:
                  if l.AsValueString() == 'tile of your desired viewport':
                           nominated_viewport_type = c
            except:
                  print('parameter does not have name')
I also received an answer form Spage which is more efficient than my approach that works perfectly. see the link below:
https://forums.autodesk.com/t5/revit-api-forum/filtering-viewport-types/m-p/9294167#M44333
Thanks for your help all.
