Viewport fails split operation and does not report error. however creates views on sheets has an unhandled exception.
FrankHolidaytoiling
FrankHolidaytoiling
I am attempting to split a viewport just after i close a transaction to place on a sheet and the creation of viewsheets fails, probably because this operation is failing. Do I need to run this as a post operation or a seperate addin? Can the operation of splitting an elevation be performed on views as well as viewports from a sheet?
using (Transaction t = new Transaction(doc, "split"))
t.Start();
    foreach (ElementId elementId in viewSheet.GetAllViewports())
        View viewport = doc.GetElement(elementId) as View;
        ViewCropRegionShapeManager cropManager = viewport.GetCropRegionShapeManager();
        if (!cropManager.CanBeSplit) throw new Exception("Cannot Split!");
         cropManager.SplitRegionHorizontally(0, 0.4999, 0.5001);
t.Commit();
moturi.magati.george
Hi @FrankHolidaytoiling,
I can see a similar question on the link below which tries to give a little bit of information of splitting a ViewPort.
https://forums.autodesk.com/t5/revit-api-forum/split-crop-already-with-splits-doesn-t-seem-to-work/t...
You can also view the links below that describes how you can split your Views.
https://forums.autodesk.com/t5/revit-api-forum/ability-to-set-split-region-offset/td-p/10042996
https://adndevblog.typepad.com/aec/2015/03/revitapi-how-to-resize-cropbox-of-view.html
  Moturi George,     Developer Advocacy and Support,  ADN Open
FrankHolidaytoiling
Thanx,
I found the first or top hyperlink already. I was not having success with basic splitting of view cropbox within a modeless form addin, so i am going to attempt it as a seperate addin.
