View - Thin Lines
View - Thin Lines
View - Thin Lines
Is there any way to get via API the current value of the Thin Lines setting from the View menu, Graphics tab?
Thank you,
Bogdan
jeremytammik
Dear Bogdan,
Sorry for the rather late reply  🙂
The answer is yes, as of Revit 2015 R2.
For more details please refer to this thread:
Exported image line weight (thin line) and rendering setting
http://forums.autodesk.com/t5/revit-api/exported-image-line-weight-thin-line-and-rendering-setting/m...
Thank you.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
A solution providing programmatic control over the Thin Lines setting is presented by Revitalizer and The Building Coder here:
http://thebuildingcoder.typepad.com/blog/2015/03/thin-lines-add-in-using-ui-automation.html
Jeremy Tammik
The Building Coder
