View Icons in Revit
View Icons in Revit
View Icons in Revit
I have to get different view icons in revit ex. Floor Plan View icon. But I'm sure that those icons are not located where revit was installed. Kindly suggest where I can get those icons.
Please refer attached image.
Thanks and Regards,
Vinoth Kumar.R
jeremytammik
Dear Vinoth,
I assume they are stored in a resource DLL in the same folder as Revit.exe, or below it, or some other, common, shared Autodesk resource directory.
Please let us know where you end up finding them.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
FAIR59
they are in the file Utility.dll in the same folder as Revit.exe
How did you read the images. When I try get "A refrance to ...Utility.dll' could not be added. Please make sure that the file is accessible, and that is is a valid assembly og COM component.
Revitalizer
for the images used in the RibbonBar, you could step through each tab, panel and item.
If a RibbonItem has a valid Image or LargeImage property, you can get this ImageSource object, convert it into a Bitmap etc. and save this wherever you want.
You can use either AdWindows.dll or plain Revit API for that purpose.
For the bitmap conversion method, please ask the search engine of your choice.
Generally, I would think the generic Revit icons are property of Autodesk (the icons of third party add-ins are property of the related developers, but may depend on the licence).
It would be better to create your own icons - please refer to "Autodesk Icon Guidelines.pdf" which is located in the Revit SDK main folder.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
hoangthanh7897
I can not find the icon in Modify Panel, but other icons. Do you know about it?
