View CropBox Resizing After Creation
Let's say I create a ViewPlan with a CropBox specified by the return value of a function "bounds(elements)".
t = Transaction(doc, "Create plan view."); t.Start()
view = ViewPlan.Create(doc, template.Id, level.Id)
view.CropBoxActive = True
view.CropBox = bounds(elements)
t.Commit()
This works well -- I get back a ViewPlan perfectly fitted around the elements I'm interested in.
Now let's say I want to change the aspect ratio of the ViewPlan after the initial commit (say, doubling the height of the CropBox). I can write a function "resize(current_cropbox, ratio)" that takes an existing ViewPlan's CropBox and desired aspect ratio and calculates a new CropBox meeting my aspect criteria. I then start a Transaction to update the CropBox:
t = Transaction(doc, "Attempt view resize"); t.Start()        view.CropBox = resize(view.CropBox, 2.0)
t.Commit()
This doesn't do anything. After the Commit(), the CropBox values remain unchanged, despite the fact that aspect() is calculating a new BoundingBoxXYZ object.
Why does this happen? Is it possible to modify a View's CropBox after creation?
I see this has been asked before:
http://forums.autodesk.com/t5/revit-api/update-view-cropbox-extents/m-p/2442052/highlight/true#M1182
...but I haven't found a clear conclusion to the problem. Any pointers are appreciated.
Thanks in advance!
NB. Tested on Revit 2014 using IronPython.
Aaron.Lu
What about this:
List<Curve> nl = new List<Curve>();
XYZ p2 = new XYZ(-10.0, 0.0, 0.0);
XYZ p3 = new XYZ(10.0, 0.0, 0.0);
XYZ p4 = new XYZ(10.0, 0.0, 10.0);
XYZ p5 = new XYZ(-10.0, 0.0, 10.0);
nl.Add(Line.CreateBound(p2, p3));
nl.Add(Line.CreateBound(p3, p4));
nl.Add(Line.CreateBound(p4, p5));
nl.Add(Line.CreateBound(p5, p2));
CurveLoop cl = CurveLoop.Create(nl);
ViewCropRegionShapeManager vpcr = view.GetCropRegionShapeManager();
bool cropValid = vpcr.IsCropRegionShapeValid(cl);
if (cropValid)
    vpcr.SetCropRegionShape(cl);
else
    TaskDialog.Show("ERROR", "Failed");
doc.Regenerate();
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Aaron.Lu
Furthermore, I created a new project, and haven't found any problem as yours.
var view = RevitDoc.ActiveView;
BoundingBoxXYZ box = new BoundingBoxXYZ();
box.Min = new XYZ(0, 0, 0);
box.Max = new XYZ(100, 100, 100);
view.CropBox = box;
transaction.Commit();
Aaron Lu
Thanks Aaron. Yes, I get the same result you do when I test on a simple sample model. I'll need to investigate the project model and code sections that caused the original problem, and see if I can recreate the result in isolation. Thanks again.
