[urgent] How clone wall with curve locked
sizy458
sizy458
In revit , When i clone a wall ,it work good.
But this code i observe.
if (true)
                                    var lc = wallClone.Location as LocationCurve;
                                    //debug
                                    XYZ l1 = lc.Curve.GetEndPoint(0);
                                    XYZ l2 = lc.Curve.GetEndPoint(1);
                                    l1 = null;
                                doc.Regenerate();
                                if (true)
                                    //debug
                                    XYZ l3 = lc.Curve.GetEndPoint(0);
                                    XYZ l4 = lc.Curve.GetEndPoint(1);
                                    l3 = null;
THEN ,
i observe that l1 different from l3 and l2 different from l4.
Why ?
How lock the curve wall for avoiding regenerate ?
Thank.
jeremytammik
I do not understand your question at all, I'm sorry to say.
However, just guessing, I would assume that you wish to perform two steps:
  • Clone a wall
  • Modify the cloned wall's location curve
I imagine that might be achievable as follows:
  Wall wall_clone = clone the wall...
  // create any kind of curve you like:
  Curve new_wall_curve = Line.CreateBound...
  wall_clone.Location = new_wall_curve;
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
sizy458
I want cloned exactly a wall
 LocationCurve locCurve = wallSource.Location as LocationCurve;
Curve cc1 = locCurve.Curve;
 wallClone = Wall.Create(doc, cc1, lvdest.Id, true);
                                    //debug
                                    l1 = null;
                                doc.Regenerate();
                                    //debug
                                    l3 = null;
Then in certain cases 'l1 'is not equal 'l3' and 'l2' is not equal 'l4'.
Why ?
jeremytammik
Revit implements a BIM.
BIM is a realistic building model.
In reality, you cannot have two walls in exactly the same place.
Therefore, Revit prevents you from having that in the BIM as well.
Please always test whatever you are trying to do manually in the user interface before even thinking about addressing it programmatically.
Jeremy Tammik
The Building Coder
