Updating View with MVVM
retug_austin
retug_austin
I made a recent post here about MVVM and keeping a list of selected elements updated with updates in the Revit model.
I have made some progress after the guidance provided in that first post, but still running into an issue I can't seem to resolve. After some review, it seemed like IUpdater interface would be the best way to keep my view up to date with the revit model changes. Full code on github.
Debugging in the Execute command, the model elements are correctly revised based on updates in performed in the revit model (see if gif below, one of the items changes from a W18x40 to a W21x44, the list of IEnumerable<RevitFramingModel> structuralFramingElements is correctly updated while debugging)
The problem, the datagrid view is not updated with this data.
Do you know where my problem is? I can't figure out why the view won't update.
Thanks!
scgq425
Hi @retug_austin :
i download u code and debug this , if u want changed type and trigged the window , need to change the code to this , also can add this code `d:DataContext="{d:DesignInstance Type = local:MainViewModel}"` to u mainwindow xaml  ,  this is easy ,so i not push this code to u github .
public class MainViewModel : INotifyPropertyChanged{
private ObservableCollection<RevitFramingModel> _structuralFramingElements = new ObservableCollection<RevitFramingModel>();
public ObservableCollection<RevitFramingModel> StructuralFramingElements
get { return _structuralFramingElements; }
set
_structuralFramingElements = value;
PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(nameof(StructuralFramingElements)));
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
retug_austin
Thanks a ton @scgq425 , this worked.
May I ask, why did you switch from IEnumerable to ObservableCollection on _stucturalFramingElements and StructuralFramingElements?
So cool seeing these sync'd up:
ricaun
When working with 'Binding' and a list of objects, it is better to use the 'ObservableCollection'.
The 'ObservableCollection' has the 'INotifyPropertyChanged' and 'INotifyCollectionChanged', if you add or remove an element by default the UI gonna be updated.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
