Updater giving a warning message before the Revit document opens
IbrahimNaeem
IbrahimNaeem
I have created an addin which use an updater, the updater works fine but have two errors:
1- First Error, when I reopen a project where I used the updater in before it's giving me a warning message that the updater used before doesn't exist. Any ideas of how to get rid of this message because the updater is there and loaded with the Revit start-up normally and works fine after I neglect this message?
2- Second Error, Sometimes it stop working but when I stop it and activate it back(have two buttons to activate it and stop it), it works fine. Any clarification why it's having this strange behavior?
Thanks, Ibrahim Naeem
matthew_taylor
Hi @IbrahimNaeem,
Have you used the 'isOptional' overload of RegisterUpdater?: http://www.revitapidocs.com/2017/b83ef3b6-e567-97ae-c33c-181b281b3287.htm
Are you unregistering/reregistering the iupdater, or just adding/removing the triggers when using your activate/stop buttons?
Are you registering the iupdater per document, or at the application level?
I'd need to see some code to comment further.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
IbrahimNaeem
What a hot-fix that is, Matt.Thank you.
matthew_taylor
A pleasure, Ibrahim!
Cheers,
-Matt
