Update Revit Plugin dll
m.walterN99B3
m.walterN99B3
Actually my Plugin is located under c:\ProgramData\Autodesk\Revit\Addins\2024\MyPlugin\MyPlugin.dll
I like to press a button in the Plugin and start an update process to replace the MyPlugin.dll and copy some files to the folder c:\ProgramData\Autodesk\Revit\Addins\2024\MyPlugin\
Is this possible?
Does the Plugin have to be closed or maybe Revit?
ricaun
If the file 'MyPlugin.dll' has been used by Revit you cannot replace the file until the Revit process finishes (close Revit).
That's how a Windows application works, if a DLL is been used by some process, is not possible to replace/delete the DLL until you finish the application that is using the file.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
m.walterN99B3
But maybe I could create a MyPluginLibrary.dll too, that is loadad by the MyPlugin.dll at runtime like this:
Assembly assembly = Assembly.LoadFrom("MyPluginLibrary.dll");
and contains the main code.
So I could Unload, Update and Load the MyPluginLibrary.dll when I need it.
Could this work?
But maybe I do not have the rights to copy files to the AddIns folder?
ricaun
If you load 'MyPluginLibrary.dll' the file gonna be used by Revit the same way as the 'MyPlugin.dll'.
Unload is not possible in the Net Framework, if the file is loaded the file is blocked until you close Revit.
The location/directory gonna depends on what your user has rights inside the folder.
You could use the folder %appdata%\Autodesk\Revit\Addins\ that is only available for the current user, and the user can do anything there.
